Ideal air loads (heating and cooling) much higher than other HVAC system loads!
As the name suggests, Ideal air loads, this suppose to estimate a small load when compared with HVAC systems. However, when I compare Ideal air loads with any other HVAC system the ideal load is always higher. Does any one knows why?
The figure below shows a comparison of different systems for my building.image description
