Can't "Apply Measure Now" for VRF with DOAS (Different Error)
Hello, I've added thermaI zone for spaces with no thermal zone and then want to input HVAC system to my model by the OpenStudio version 1.12.0 "Apply Measure Now". I'm using OpenStudio version 1.12.0 and also Sketchup 2016. I've selected VRF with DOAS as the HVAC system but when it started to load "measure now" but it ended with the message box
error: process exited with a non-zero exit code of: 1
DL is deprecated, please use Fiddle
from C:/Users/Abdih/AppData/Local/Temp/OpenStudio.Ds3484/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:1137:in `createVRFAirConditioners'Fiddle
C:/Users/Abdih/AppData/Local/Temp/OpenStudio.Ds3484/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:1181:in `setZoneforMasterThermostatLocation': invalid null reference Expected argument 1 of type openstudio::model::ThermalZone const &, but got NilClass nil (ArgumentError)
in SWIG method 'setZoneforMasterThermostatLocation'
from C:/Users/Abdih/AppData/Local/Temp/OpenStudio.Ds3484/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:1181:in `block in createVRFAirConditioners'
from C:/Users/Abdih/AppData/Local/Temp/OpenStudio.Ds3484/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:1137:in `each'
from C:/Users/Abdih/AppData/Local/Temp/OpenStudio.Ds3484/ApplyMeasureNow/UserScript/user_script.rb:388:in `run'
from in.rb:355:in `<main>'
Perhaps there is another solution for this problem?
