Externally Calculated Renewable Energy as Input to EnergyPlus
Hi Modeling Community,
I am calculated the amount of electrical and thermal energy collected from a renewable energy system externally to EnergyPlus. I would like to input the amount generated into EnergyPlus' energy balance but I'm not sure how.
Is there an electrical component that can read values from a schedule or actuator that can subtract energy? I found ElectricalLoadCenter:Generators but it seems to be overly complex and the Photovoltaic:Simple also requires specifications of a PV array.
What about a thermal energy input, maybe a heat exchanger or thermal storage tank?
Thank you for your time,
Justin
Justin
click to hide/show revision 3
No.3 Revision
What about a thermal energy input, maybe a heat exchanger or thermal storage tank?tank? Edit: As a point of clarity, the thermal energy would be best added to an HVAC system input to reduce the load on a boiler.
Justin
click to hide/show revision 4
No.4 Revision
What about a thermal energy input, maybe a heat exchanger or thermal storage tank? Edit: As a point of clarity, the thermal energy would be best added to an HVAC system input to reduce the load on a boiler.
Justin
Edit 2: Still looking for a way to add renewable energy or subtract energy from the total building consumption.
click to hide/show revision 5
No.5 Revision
Justin
Edit 3: Providing a negative value to ElectricEquipment does not appear as though it will work because it returns the below fatal error.
   ** Severe  ** Out of range value Numeric Field#1 (Design Level), value=-456.00000, range={>=0}, in ELECTRICEQUIPMENT=SPACE2-1 ELECEQ NEGATIVE
   ** Severe  ** IP: Out of "range" values found in input
   ** Severe  ** IP: Out of "range" values and/or blank required fields found in input
   **  Fatal  ** IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination.
