Hello, I want to input HVAC system to my model by the OpenStudio version 1.12.0 "Apply Measure Now". I'm using OpenStudio version 1.12.0 and also Sketchup 2016. I've selected VRF with DOAS as the HVAC system but when it started to load "measure now" it always ended with the message box
error: process exited with a non-zero exit code of: 1
DL is deprecated, please use Fiddle
C:/Users/Abdih/AppData/Local/Temp/OpenStudio.Wm3296/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:126:in get': Optional not initialized (RuntimeError)
from C:/Users/Abdih/AppData/Local/Temp/OpenStudio.Wm3296/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:126:inblock in sortZones'
from C:/Users/Abdih/AppData/Local/Temp/OpenStudio.Wm3296/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:121:in each'
from C:/Users/Abdih/AppData/Local/Temp/OpenStudio.Wm3296/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:121:insortZones'
from C:/Users/Abdih/AppData/Local/Temp/OpenStudio.Wm3296/ApplyMeasureNow/UserScript/user_script.rb:246:in run'
from in.rb:355:in<main>'
It happened with every single model I've made. Any suggestion what should I do?
