I'm trying to combine the Parametrics feature with EMS, and getting an error. I'm using 8.5 Here is the definition of my parametrics:
Parametric:SetValueForRun,
$SP_parametric, !- Parameter Name
0,
50,
100,
500,
1000;
And here is how I'm trying to use it in an EMS section:
Control0,
IF Sensor0 < =$SP_parametric,
SET Actuator0 = VDG_clear,
The error I'm getting is:
** Fatal ** EMS, caught unexpected token = "=" ; while parsing string=SENSOR0 < =$SP_PARAMETRIC
Is there a different way I should format the parameter reference so I can use it with the EMS?
Thanks
Christian
