Hi all,
I'm working on a script that will grab all osm files in a directory and simulate them. I took some pointers from an example file called RunAllOSMs.rb but hit a snag. Mostly I'm finding it difficult to understand what exactly goes on throughout certain parts of that script. Below you'll find my attempt at modifying RunAllOSMs.rb to fit my needs:
Relevant snippet from ruby script:
#simulate all osms
puts "\nBeginning simulations..."
#set OS paths
output_os_path = OpenStudio::Path.new(output_dir)
weather_os_path = OpenStudio::system_complete(OpenStudio::Path.new(weather_file_dir))
#Create run manager
runManagerDBPath = output_os_path / OpenStudio::Path.new("RunManager.db")
puts "Creating RunManager database at " + runManagerDBPath.to_s + "."
OpenStudio::remove(runManagerDBPath) if (OpenStudio::exists(runManagerDBPath))
runManager = OpenStudio::Runmanager::RunManager.new(runManagerDBPath,true)
# find energyplus
ep_path = OpenStudio::Path.new('C:\EnergyPlusV8-5-0')
tools = OpenStudio::Runmanager::ConfigOptions::makeTools(ep_path.parent_path(),
OpenStudio::Path.new,
OpenStudio::Path.new)
#Loop through each osm in output directory and simulate them
Dir[output_dir + "/*.osm"].each do |osm_file|
#Add osm to queue
relative_file_path = OpenStudio::relativePath(OpenStudio::Path.new(osm_file),output_os_path)
puts "Queuing simulation job for " + osm_file.to_s + "."
osm_path = output_os_path/relative_file_path
#create workflow
workflow = OpenStudio::Runmanager::Workflow.new("modeltoidf->energyplus->openstudiopostprocess")
workflow.setInputFiles(osm_path, weather_os_path)
workflow.add(tools)
# create and queue job
jobDirectory = osm_path.parent_path() / OpenStudio::Path.new(osm_path.stem()) / OpenStudio::Path.new("/")
puts "Job directory will be '" + jobDirectory.to_s + "'."
job = workflow.create(jobDirectory)
runManager.enqueue(job, true)
end
Here is the error I receive when running my script:
[utilities.idf.Workspace] <1> URL Found in IDF: file:files/USA_IL_Chicago-OHare.Intl.AP.725300_TMY3.epw but no source could be located.
This epw file is in the directory specified under weather_file_dir, so I'm confused as to why this happens. The line that causes this print out is the following:
From what I can tell, the directories are being assigned correctly, so I'm guessing it maybe due to my understanding of what happens with my workflow object? Do I have to somehow tell it to create that files directory and populate it with the epw file beforehand? Any advice would be greatly appreciated. I haven't had much success understanding the documentation.
Thanks!
