Can I adjust HVAC equipment on a schedule in eQuest?
I'm preparing an energy model in eQuest for a multifamily apartment building and have run into an issue with the DOAS system.
The building has (2) AHU units supplying 100% outside air which is conditioned by a CHW and HW Loop. There is one larger unit at an estimated 18,000 cfm and a smaller unit at 12,000 cfm. Currently, they are modeled together as one 30,000 cfm VAV (with the OA and fan max and min ratios both set to 1 in order to accurately represent the operating conditions of the actual equipment).
I was informed by the facility manager today that the larger AHU was actually not working for 6 months out of the year. This explains why my calibration was off during those months. Anyway, is there a way to mimic this in eQuest?
  • A way to assign a single zone to (2) DOAS systems and then kill the fan power to one of them with a schedule
  • Drop the CFM for the combined DOAS at a certain month during the year with a schedule?
  • Any other method you guys might have?
Thanks for the help!
click to hide/show revision 2
No.2 Revision
Can I adjust HVAC equipment fan CFM on a schedule in eQuest?
Can I adjust fan CFM on a schedule in eQuest?
