problem openning reference building model idf files in OpenStudio (08.2016)
Hello,
I am trying to import the idf files of DOE's reference building models into OpenStudio 1.12.0 but I get the error message: "File is not valid to draft strictness". I read in other posts that this is a common issue with the idf files but in my case no info (HVAC, construction, schedule, nothing) is imported into OpenStudio. Any help would be appreciated.
Is there a place to directly download the OSM versions of DOE's idf files?
Thank you very much.
Hello,
Hello,
Thank you very much. files?
problem Problem openning reference building model idf files in OpenStudio (08.2016)
