I am trying to model HW system but I sometimes I get errors regarding controls as described below. When I try a test one space building it works but with my building, there are always errors. I checked out all schedules and setting but no way. Your help is appreciated in advance.
image of my loop C:\fakepath\Untitled.png
Program Version,EnergyPlus, Version 8.4.0-832e4bb9cb, YMD=2016.08.16 08:41,IDD_Version 8.4.0 *** IDF Context for following error/warning message: *** Note -- lines truncated at 300 characters, if necessary... *** 4445 PlantEquipmentOperationSchemes, *** indicated Name=Plant Loop 1 Operation Schemes *** Only last 4 lines before error line shown..... *** 4446 Plant Loop 1 Operation Schemes, !- Name *** 4447 PlantEquipmentOperation:HeatingLoad, !- Control Scheme Object Type 1 *** 4448 Plant Loop 1 Heating Operation Scheme, !- Control Scheme Name 1 *** 4449 ; !- Control Scheme Schedule Name 1 * Severe * IP: IDF line~4449 Error detected in Object=PLANTEQUIPMENTOPERATIONSCHEMES, name=PLANT LOOP 1 OPERATION SCHEMES * ~~~ * Field [Control Scheme 1 Schedule Name] is required but was blank * Warning * IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details. * Severe * IP: Blank "required" fields found in input * Severe * IP: Out of "range" values and/or blank required fields found in input * Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=3 ..... Last severe error=IP: Out of "range" values and/or blank required fields found in input *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 1 Warning; 3 Severe Errors; Elapsed Time=00hr 00min 0.48sec
