Hi Energy Modeling Community,
I'm setting up a very simple co-simulation between EnergyPlus and a Functional Mockup Unit (FMU). The FMU is configured to return a fraction that would be fed into an OtherEquipment object as the Schedule Name input. For now I just wanted to report the result of the simulation to check if the communication is working. I used the EnergyPlus example 1ZoneUncontrolled to which I added the lines below.
ExternalInterface,
FunctionalMockupUnitImport; !- Name of External Interface
ExternalInterface:FunctionalMockupUnitImport,
OtherEquipmentFraction.fmu, !- FMU File Name
15, !- FMU Timeout {ms}
0; !- FMU LoggingOn
ExternalInterface:FunctionalMockupUnitImport:From:Variable,
ZONE ONE, !- Output:Variable Index Key Name
Zone Outdoor Air Drybulb Temperature, !- Output:Variable Name
OtherEquipmentFraction, !- FMU Instance Name
EnvironmentAirTemp; !- FMU Variable Name
Zone Mean Air Temperature, !- Output:Variable Name
ZoneAirTemp; !- FMU Variable Name
ExternalInterface:FunctionalMockupUnitImport:To:Schedule,
TEST352aNewPowerLevel, !- Name
Fraction, !- Schedule Type Limits Names
OEFraction, !- FMU Variable Name
1; !- Initial Value
Output:Variable,*,Schedule Value,hourly;
I have previously had this model working on EnergyPlus 8.1.0x86 but wanted to try using EnergyPlus 8.5.0x86. When I setup and run the simulation I receive the error:
** Fatal ** IP: GetObjectItem: ExternalInterface:FunctionalMockupUnitImport:To:Schedule, Number of ObjectDef Alpha Args [5] > Size of AlphaArg array [3].
I looked into ObjectDef Alpha Args and AlphaArg array and found a discussion of EnergyPlus's IDD file and the developer guide. Do I need to edit the IDD file in some way to support the FMU functionality I am attempting to use above? Should I use an older version of EnergyPlus?
