Using Eppy to replace recurring strings in an IDF file
Hello, I am trying to pre-process an IDF file (exported from DesignBuilder or OpenStudio) to use it with jEPlus.
As I am trying to 'assemble' a custom IDF file, using bits and pieces from different sources, I would like to manipulate an IDF, exported from DB, to combine it with objects that have customised names.
For surfaces, I managed to replace each surface name with a simpler name, the latter including the name of the zone, the type of surface and its azimuth.
The code:
s_names_azm = [(sf.Name, sf.azimuth) for sf in surfaces]
for name, azimuth in s_names_azm[:5]:
    print '\n', name, azimuth
    name = name.split(':',1)[1]
    name = name.split('_',2)[0] + '_' + name.split('_',2)[1] + '_' + str(azimuth)
    print name
returns:
Block1:B1_GroundFloor_0_0_0 0.0
B1_GroundFloor_0.0
Block1:B1_Roof_1_0_0 0.0
B1_Roof_0.0
Block1:B1_Partition_2_0_0 90.0
B1_Partition_90.0
Block2:LR_Partition_4_0_10000 270.0
LR_Partition_270.0
Block1:B1_Wall_3_0_0 0.0
B1_Wall_0.0
which is what I wanted.
However, you all know that names are always cross referenced in a IDF file, thus what I am after is really a script capable of running a find and replace function throughout the IDF file.
Is there a way to run the string.replace(old_name, new_name) for an entire IDF file?
click to hide/show revision 2
No.2 Revision
The code:
    print name
returns:
B1_GroundFloor_0.0
B1_Roof_0.0
B1_Partition_90.0
LR_Partition_270.0
B1_Wall_0.0
Is there a way to run the string.replace(old_name, new_name) for an entire IDF file?file? My aim is that every string 'Block*:' is replaced with '' (so effectively deleted).
Thanks, Andrea
click to hide/show revision 3
No.3 Revision
The code:
    print name
returns:
B1_GroundFloor_0.0
B1_Roof_0.0
B1_Partition_90.0
LR_Partition_270.0
B1_Wall_0.0
Is there a way to run the string.replace(old_name, new_name) for an entire IDF file? My aim is that every string 'Block*:' is replaced with '' (so effectively deleted).
Thanks, Andrea
EDIT: The code:
surfaces = idf1.idfobjects['BUILDINGSURFACE:DETAILED']
for name, azimuth in s_names_azm:
does achieve the renaming I am after (where the input happens before Jamie Bull's substitution function).
However it does not seem to modify any object in the idf file (even though a saveas command is included at the end of the script). Why??
The code:
    print name
returns:
B1_GroundFloor_0.0
B1_Roof_0.0
B1_Partition_90.0
LR_Partition_270.0
B1_Wall_0.0
Thanks, Andrea
EDIT: The code:
The code:
    print name
returns:
B1_GroundFloor_0.0
B1_Roof_0.0
B1_Partition_90.0
LR_Partition_270.0
B1_Wall_0.0
Thanks, Andrea
EDIT: The code:
