Hello, I am trying to pre-process an IDF file (exported from designbuilder or openstudio) to use it with jEplus. Thanks to the help I received on this forum I have managed to replace selected parameters with jeplus variables, which is great.
My next step is to 'assemble' and IDF file, by:
- extracting objects from an IDF files
- save them as a separate IDF files (or INP input file) to be subsequently called by EP-macro, within jEplus.
For instance, I would like to use the geometry built with DesignBuilder - by extracting idf.idfobjects['BUILDINGSURFACE:DETAILED'] - and copy this in a new file where all other objects are called through EP-macro (i.e. schedules, materials, output variables etc).
Also, could these objets be exported in a different format, (i.e. csv) in order to visualise them?
I have tried to use the commands .saveas() and .to_csv in eppy but neither of those seem to work.
Thanks! Andrea
