Dear All,
I am trying to run energyplus on a the Iridis server which is a shared facility used by UCL that runs on 64 bit Red Hat Enterprise Linux Server release 5 (Tikanga).
I first tried to run the installation script from https://github.com/nrel/EnergyPlusRelease/releases This didn't work because it must have been built on a different version of linux and I got the following error when I tried to runenergyplus: /lib64/libc.so.6: version 'GLIBC_2.14' not found I was wondering if there is a RHEL version like there was for version 7: https://groups.yahoo.com/neo/groups/EnergyPlus_Support/conversations/messages/27836
I also tried to compile the code myself from source but have had little luck with that. I'm trying to follow the instructions for linux from here: https://github.com/NREL/EnergyPlus
The instructions aren't great because it doesn't tell you how to configure ccmake. I've tried compiling the Fortran bit and it gets to about 92% and then fails:
File all' does not exist.
make[1]: Targetall' not remade because of errors.
make: * [all] Error 2
File default_target' does not exist.
make: Targetdefault_target' not remade because of errors.
I did manage to get it to compile with BUILD_PACKAGE turned on but that doesn't produce the ExpandObjects executable and so energyplus won't run.
Please help,
Phil
