you can help for program energyplus
Im write a program with Energy plus for calculate lighting for plan .But after lighting program and register for specific zones on each floor.When we run the software are identical points obtained for different classes . And while the amount of illumination increases with height values ​​must be different answer . Please can someone help me . Yours sincerely kourosh. best regard for you.
