How can i setting the Reflection on Radiance Simulation model? where the setting? in my model i must no using reflection of the daylight, is there any solution?
![]() | 1 | initial version |
![]() | 2 | retagged |
![]() | 3 | No.3 Revision |
i'am using OpenStudio Radiance 1.11 to simulate the illuminance map of my object. My research is focus on the Daylight potential on the building. its a good thing, if i can costumize the Reflection Factor of my model. Is it possible?
*image explain :
----- > is full window (in sketchup, i just break the wall. without install the 3D warehouse window) ____> is full wall, there no ventilation
For example, i upload the result of the First Zone based on image (.osm) file. https://www.dropbox.com/sh/c4tu1u5geyprbhu/AAAMrs5D6xF0AE4WVgtN45Dca?dl=0
![]() | 4 | No.4 Revision |
*image explain :
____> window)
_______> is full wall, there no ventilation
![]() | 5 | retagged |
*image explain :
![]() | 6 | No.6 Revision |
*image explain :
![]() | 7 | retagged |
*image explain :
