HI, I'm learning E+ and bcvtb (mle+) and when I run the example it has an error:
* Severe * ExternalInterface: Socket communication received error value " 1" at time = 0.10 hours. * ~~~ * ExternalInterface: Flag from server " 1". * Fatal * Error in ExternalInterface: Check EnergyPlus *.err file.
while in Matlab it shows: Reference to non-existent field 'Shade_Status_Off'.
Error in control_file_blind_angle (line 36) ShadeStatus = userdata.Shade_Status_Off;
Error in mlepRunTemplateSysID (line 157) [inputStruct, mlep.data.userdata] = feval(mlep.data.funcHandle, cmd, mlepOut, mlepIn, time(1:kStep), kStep, mlep.data.userdata); %.data.userdata NEED TO CHANGE,eplusOutPrev, eplusInPrev, time Error in mlepSimulateFunction>runSimulation (line 43) [data.time data.input data.output mlep] = mlepRunTemplateSysID(mlep);
Error in mlepSimulateFunction (line 10) [mlep] = runSimulation(mlep);
Error while evaluating uicontrol Callback
I use the newest E+ version, also tried the previous v.8.00 version, which had the same problem.
I found an answer in previous question which gave a link but can not use now: https://corbu.lbl.gov/svn/fmu/EnergyPlus/export/trunk/
I don't know how to fix it, and why the field 'Shade_Status_Off' does not exist? it is in the userData.mat.
Thanks. Kay
