I'm up against a recurring error very similar to the one described here.
The issue is a blank field for the Induced Air input field of a Four Pipe Induction Terminal supplied by Air Handling Unit 1. The interesting thing here is that every time I add a new terminal unit in a new zone the error seems to move to another (the new) terminal unit.
* Severe * IP: IDF line~7462 Error detected in Object=AIRTERMINAL:SINGLEDUCT:CONSTANTVOLUME:FOURPIPEINDUCTION, name=THB.08 * ~~~ * Field [Induced Air Inlet Node Name] is required but was blank
*** 7457 THB.08, !- Name *** 7458 , !- Availability Schedule Name *** 7459 0.48, !- Maximum Total Air Flow Rate {m3/s} *** 7460 2.5, !- Induction Ratio *** 7461 Node 622, !- Supply Air Inlet Node Name *** 7462 , !- Induced Air Inlet Node Name
I tried changing the type of analysis to detailed analysis as mentioned here, but that didn't make any difference.
In addition, the simulation ran before, but once I added additional ZoneExhaust and Ventilation:DesignFlowRate objects it started failing, maybe that has something to do with it.
Here is a link to the OpenStudio file.
