I've got this project that I need to complete within the next 24 hours and it keeps failing when it comes up to the EnergyPlus simulation. I tried previous saved files of my model and it fails at the same point so I have no clue what I'm doing wrong. Any help would be appreciated!
This is the output that I am currently getting. It stops at 75% every single time.
" ExpandObjects Started. Begin reading Energy+.idd file. Done reading Energy+.idd file. ExpandObjects Finished. Time: 0.438 Script executing from: C:/Users/Family PC/AppData/Local/Temp/OpenStudio.pC6568/resources/run/3-UserScript-0 Found argument 'measures_json' with value '[{"arguments":{},"measure":"C:/Program Files/OpenStudio 1.12.0/share/openstudio-1.12.0/pat/Measures/StandardReports/measure.rb"}]'. Found UserScript 'Report Request'. Looking for building_summary_section (Model Summary) Boolean, Required Value: (true) Looking for annual_overview_section (Annual Overview) Boolean, Required Value: (true) Looking for monthly_overview_section (Monthly Overview) Boolean, Required Value: (true) Looking for utility_bills_rates_section (Utility Bills/Rates) Boolean, Required Value: (true) Looking for envelope_section_section (Envelope) Boolean, Required Value: (true) Looking for space_type_breakdown_section (Space Type Breakdown) Boolean, Required Value: (true) Looking for space_type_details_section (Space Type Summary) Boolean, Required Value: (true) Looking for interior_lighting_section (Interior Lighting Summary) Boolean, Required Value: (true) Looking for plug_loads_section (Plug Loads Summary) Boolean, Required Value: (true) Looking for exterior_light_section (Exterior Lighting) Boolean, Required Value: (true) Looking for water_use_section (Water Use Equipment) Boolean, Required Value: (true) Looking for hvac_load_profile (HVAC Load Profiles) Boolean, Required Value: (true) Looking for zone_condition_section (Zone Conditions) Boolean, Required Value: (true) Looking for zone_summary_section (Zone Overview) Boolean, Required Value: (true) Looking for zone_equipment_detail_section (Zone Equipment Detail) Boolean, Required Value: (true) Looking for air_loops_detail_section (Air Loops Detail) Boolean, Required Value: (true) Looking for plant_loops_detail_section (Plant Loops Detail) Boolean, Required Value: (true) Looking for outdoor_air_section (Outdoor Air) Boolean, Required Value: (true) Looking for cost_summary_section (Cash Flow) Boolean, Required Value: (true) Looking for source_energy_section (Site and Source Summary) Boolean, Required Value: (true) Looking for schedules_overview_section (Schedule Overview) Boolean, Required Value: (true) result = true Processed 1 base script and 0 merged scripts EnergyPlus Starting EnergyPlus, Version 8.5.0-c87e61b44b, YMD=2016.07.17 23:41 Processing Data Dictionary Processing Input File Initializing Simulation"
If you require the file to help me out, I am able to provide it. Thanks.
