Hello,
I would like to learn how to specify load definitions by end-use within OpenStudio. For example, I have created process lighting definitions that I would like to see under Interior Lighting (process) not bundled under Interior Lighting. Same goes for electric equipment definitions for elevators, cooking equipment, etc. as all electric equipment is bundled under receptacle equipment.
Is this possible within OpenStudio platform? Can you do this by editing .osm file? How would you do this in the .idf if needed?
Thank you, Brian
