Dear everyone,
I used the SurfaceProperty:SolarInidentInside object to calculate the effect on the building energy balance of reflected sunpactes on the ceiling inside a rectangular room. Using Radiance i computed the schedule of the solar incidence values for that surface and then fed it to E+ for simulation. I get this warning:
* Warning * Zone THERMAL_ZONE does not have all surfaces scheduled with surface gains. * ~~~ * If at least one surface in the zone is scheduled with surface gains, then all other surfaces within the same zone should be scheduled as well. * ~~~ * Surface 245779 does not have scheduled surface gains. * ~~~ * Surface 5B30C6 does not have scheduled surface gains. * ~~~ * Surface C0C614 does not have scheduled surface gains. * ~~~ * Surface THERMAL_ZONE_WINDOW_LOWER does not have scheduled surface gains. * ~~~ * Surface THERMAL_ZONE_WINDOW _UPPER does not have scheduled surface gains. * ~~~ * Surface DC934B does not have scheduled surface gains. * ~~~ * Surface AE57E2 does not have scheduled surface gains.
Does this message means that in order to implement the SolarInsidentInside object I must create schedules for all the solar gains of the surfaces of the space ?
If only one surface is scheduled does E+ also takes into account the solar gains from the other surfaces that are not scheduled during simulation?
Thank you in advance, Antonis.
