Hi All,
First of all, can we consider "Face Conduction Heat Transfer Rate per Area" on a surface face(inside/outside) in ConductionTransferFunction method same as "Surface Heat Flux" on the boundary nodes of a surface in ConductionFiniteDifference method. Same not in the terms of value but in the terms of meaning and how these both values are calculated in EP.
I am comparing heat flux from an experimental data (DSC) of a specimen with a virtual specimen in EP and in that error results from CTF algorithm looks better than CFD algorithm.
Has anybody experienced this before and if so what can be the reasons?
Thanks
