Hi,
I'm modeling a geotab system for a building. The system has a borehole field connected to a heat pump for heating. As for cooling, I use the water temperature coming from the ground 12-13°C to do some free cooling.
On DesignBuilder, we cannot connect directly the borehole fields to the secondary loop, but we need to set a cooling heat pump with its characteristics. Do you know how to model this passive cooling by eliminating the cooling capacity of the HP? I hope I was clear.
Many Thanks,
