I try to model a double-flow ventilation with the "heat exchanger air to air sensible and latent" but I don't know how I should draw my system in the "HVAC Systemps" in OpenStudio... Thank's for your help :)
| 1 | initial version |
| 2 | No.2 Revision |
I try to model a double-flow ventilation with the "heat exchanger air to air sensible and latent" but I don't know how I should draw my system in the "HVAC Systemps" Systems" in OpenStudio...
| 3 | retagged |
I try to model a double-flow ventilation with the "heat exchanger air to air sensible and latent" but I don't know how I should draw my system in the "HVAC Systems" in OpenStudio... Thank's for your help :)
