building 1.4.0-LTS in Linux
Hello OpenStudio Team:
I have recently compiled OpenStudio 1.11.4 in Ubuntu 14.04. I build the python bindings. The program and the 'py bind' are working perfectly.
I have decided to probe OpenStudio 1.4.0 Long Term Support, because I need OpenStudio linked to QT4.
Initially I had a problem with Ruby, but I can resolved it installing ruby-dev(https://github.com/NREL/OpenStudio/issues/1260).
Now I have other problem with libboost:
# error Compiling Filesystem version 3 file with BOOST_FILESYSTEM_VERSION defined != 3
and later
error: ‘external_string_type’ is not a member of ‘boost::filesystem::wpath {aka boost::filesystem::path}’
This problem happens with Ubuntu 12.04, 14.04 and 16.04, building Boost (1.47) or not.
I have working around (http://www.boost.org/doc/libs/1_46_1/libs/filesystem/v3/doc/index.htm) but it does not make sense.
Please, has recently anybody built OpenStudio 1.4.0-LTS in a linux environment successfully?
Thanks
and later
Thanks
