Hi all,
I'm new to both the forums and OS so bear with me if this is a simple fix.
I received the following error when trying to run my simulation:
* ~~~ * Field [Reference Setpoint Node Name] is required but was blank
*** IDF Context for following error/warning message:
*** Note -- lines truncated at 300 characters, if necessary...
*** 6566 SetpointManager:MixedAir,
*** indicated Name=Setpoint Manager Mixed Air 2
*** Only last 5 lines before error line shown.....
*** 6567 Setpoint Manager Mixed Air 2, !- Name
*** 6568 Temperature, !- Control Variable
*** 6569 , !- Reference Setpoint Node Name
*** 6570 Node 31, !- Fan Inlet Node Name
*** 6571 , !- Fan Outlet Node Name
* Severe * IP: IDF line~6571 Error detected in Object=SETPOINTMANAGER:MIXEDAIR, name=SETPOINT MANAGER MIXED AIR 2
* ~~~ * Field [Fan Outlet Node Name] is required but was blank
What is driving me nuts is that I have not only deleted "Setpoint Manager Mixed Air 2" but even went so far as to go ahead and delete the whole airloop associated with it to see if I can get this error to stop showing up. Prior to deleting it, I looked into the Setpoint manager and those missing nodes were specified, further adding to the confusion.
Anyone have any ideas why OS hasn't removed that setpoint manager?
