running failed in open studio, stopped at 75%
in open studio running simulation, it doesn't do more than 75% and here what is written: Looking for plug_loads_section (Plug Loads Summary) Boolean, Required Value: (true) Looking for exterior_light_section (Exterior Lighting) Boolean, Required Value: (true) Looking for water_use_section (Water Use Equipment) Boolean, Required Value: (true) Looking for hvac_load_profile (HVAC Load Profiles) Boolean, Required Value: (true) Looking for zone_condition_section (Zone Conditions) Boolean, Required Value: (true) Looking for zone_summary_section (Zone Overview) Boolean, Required Value: (true) Looking for zone_equipment_detail_section (Zone Equipment Detail) Boolean, Required Value: (true) Looking for air_loops_detail_section (Air Loops Detail) Boolean, Required Value: (true) Looking for plant_loops_detail_section (Plant Loops Detail) Boolean, Required Value: (true) Looking for outdoor_air_section (Outdoor Air) Boolean, Required Value: (true) Looking for cost_summary_section (Cash Flow) Boolean, Required Value: (true) Looking for source_energy_section (Site and Source Summary) Boolean, Required Value: (true) Looking for schedules_overview_section (Schedule Overview) Boolean, Required Value: (true) result = true Processed 1 base script and 0 merged scripts EnergyPlus Starting EnergyPlus, Version 8.5.0-c87e61b44b, YMD=2016.06.15 08:18 Processing Data Dictionary Processing Input File **FATAL:IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. EnergyPlus Run Time=00hr 00min 0.65sec
click to hide/show revision 2
No.2 Revision
in open studio running simulation, it doesn't do more than 75% and here what is written: written:
Looking for plug_loads_section (Plug Loads Summary) Boolean, Required Value: (true) Required
Value: (true)
Looking for exterior_light_section (Exterior Lighting) Boolean, Required Required
Value: (true) Looking for water_use_section (Water Use Equipment) Boolean, Required Value: (true) Equipment)
Boolean, Required
Value: (true)
Looking for hvac_load_profile (HVAC Load Profiles) Boolean, Required Value: (true) Profiles)
Boolean, Required
Value: (true)
Looking for zone_condition_section (Zone Conditions) Conditions)
ExpandObjects Started.
No expanded file generated.
ExpandObjects Finished. Time: 0.031
Script executing from: C:/Users/ESS/AppData/Local/Temp/OpenStudio.ne9348/resources/run/3-UserScript-0
Found argument 'measures_json' with value '[{"arguments":{},"measure":"C:/Program Files/OpenStudio 1.11.0/share/openstudio-1.11.0/pat/Measures/StandardReports/measure.rb"}]'.
Found UserScript 'Report Request'.
Looking for building_summary_section (Model Summary)
Boolean, Required
Value: (true)
Looking for annual_overview_section (Annual Overview)
Boolean, Required
Value: (true)
Looking for monthly_overview_section (Monthly Overview)
Boolean, Required
Value: (true) Looking for utility_bills_rates_section (Utility Bills/Rates)
Boolean, Required
Value: (true)
Looking for envelope_section_section (Envelope)
Boolean, Required
Value: (true)
Looking for space_type_breakdown_section (Space Type Breakdown)
Boolean, Required
Value: (true)
Looking for space_type_details_section (Space Type Summary)
Boolean, Required
Value: (true)
Looking for interior_lighting_section (Interior Lighting Summary)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required Value: (true) (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Looking for zone_summary_section (Zone Overview) Boolean, Required Overview)
Boolean, Required
Value: (true) Looking for zone_equipment_detail_section (Zone Equipment Detail) Boolean, Required Value: (true) Detail)
Boolean, Required
Value: (true)
Looking for air_loops_detail_section (Air Loops Detail) Boolean, Required Value: (true) Detail)
Boolean, Required
Value: (true)
Looking for plant_loops_detail_section (Plant Loops Detail) Boolean, Required Value: (true) Detail)
Boolean, Required
Value: (true)
Looking for outdoor_air_section (Outdoor Air) Boolean, Required Value: (true) Looking for cost_summary_section (Cash Flow) Boolean, Required Value: (true) Looking for source_energy_section (Site and Source Summary) Boolean, Required Value: (true) Summary)
Boolean, Required
Value: (true)
Looking for schedules_overview_section (Schedule Overview) Boolean, Required Value: (true) Overview)
Boolean, Required
Value: (true)
result = true true
Processed 1 base script and 0 merged scripts scripts
EnergyPlus Starting Starting
EnergyPlus, Version 8.5.0-c87e61b44b, YMD=2016.06.15 08:18 15:15
Processing Data Dictionary Dictionary
Processing Input File File
**FATAL:IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. EnergyPlus Run Time=00hr 00min 0.65sec0.39sec
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
Boolean, Required
Value: (true)
result = true
EnergyPlus Starting
Starting EnergyPlus, Version 8.5.0-c87e61b44b, YMD=2016.06.15 15:15
15:15 Processing Data Dictionary
File **FATAL:IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. EnergyPlus Run Time=00hr 00min 0.39sec
0.39sec
EnergyPlus Starting
click to hide/show revision 6
No.6 Revision
click to hide/show revision 7
No.7 Revision
