I want to know, if the Zone Air System Sensible Heating Rate is the energy, which is used by the HVAC.
In Input Output Refernce is declared that is the energy which is influenced by the environmental. Lock at Output Input Reference
These values are calculated by multiplying the supply air mass flow rate by the difference between the supply air temperature and the zone air temperature. This does not always indicate the operation of heating or cooling coils. For example, cooling will be reported if the supply air is cooled due to the introduction of outside air, even if all coils are off.
I want to have the energy, which is used by the HVAC and I need it hourly. Thanks for help
