Hi,
I am exploring a workflow that involves exporting a gbXML file from a Revit model and converting the gbMXL file to an IDF file via OpenSudio. I encounter an empty required field problem that cause errors when running an EmergyPlus simulation using the converted IDF file.
I came across a forum post related to this problem and tried to follow the discussion; however, I still cannot find a solution. Here is the post: https://unmethours.com/question/16600/problems-between-revit-and-openstudio. In the discussion, I acknowledge that it's a known bug and has been solved in the late versions on OpenStudio. Furthermore, the conversation seems to focus on window problems. I basically encounter problems with the building shells (e.g., floors, wall, and roof), as well.
Regarding my workflow, I installed OpenStudio 1.11.5 which exports EnergyPlus 8.5. I imported a gbXML file via the OpenStudio extension installed inside SketchUp 2016. I exported an IDF file. I examined the IDF file via a text editing tool and found that the values for the 'Construction Name' fields are empty (please see an example below), which causes errors when running the simulation.
BuildingSurface:Detailed,
aim0149, !- Name
Wall, !- Surface Type
, !- Construction Name
aim0024 ThermalZone, !- Zone Name
Could anyone please share your insights regarding how to overcome this issue? I am very open to less-manual-editing ideas whether the issue should be solved in Revit, SketchUp, OpenStudio, IDFEditor, or other third-party software.
Thank you very much.
