I am trying to apply the whole system VRF with DOAS measure to an OSM coming out of CBECC-Com.
when I do I am getting the following error:
DL is deprecated, please use Fiddle
C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.N14360/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:122:in `get': Optional not initialized (RuntimeError)
from C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.N14360/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:122:in `block in sortZones'
from C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.N14360/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:121:in `each'
from C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.N14360/ApplyMeasureNow/UserScript/resources/OsLib_HVAC.rb:121:in `sortZones'
from C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.N14360/ApplyMeasureNow/UserScript/user_script.rb:246:in `run'
from in.rb:355:in `<main>'
Script executing from: C:/Users/EBS Bootcamp/AppData/Local/Temp/OpenStudio.N14360/ApplyMeasureNow/UserScript Found argument 'vrfCondenserType' with value 'AirCooled'. Found argument 'vrfCoolCOP' with value '3.4'. Found argument 'vrfHeatCOP' with value '3.6'. Found argument 'vrfMinOATHPHeat' with value '-4'. Found argument 'vrfDefrost' with value 'Resistive'. Found argument 'vrfHPHeatRecovery' with value 'Yes'. Found argument 'vrfEquivPipingLength' with value '100'. Found argument 'vrfPipingHeight' with value '35'. Found argument 'doasFanType' with value 'Variable'. Found argument 'doasERV' with value 'none'. Found argument 'doasEvap' with value 'none'. Found argument 'doasDXEER' with value '11'. Found argument 'costTotalHVACSystem' with value '0'. Found argument 'remake_schedules' with value 'true'. Found UserScript 'VRFwithDOAS'
the existing (un-BCL-ified) OSM run to completion with only the normal assortment of errors. I found a number of other similar seeming errors but none of the solutions seem to apply here.
any help would be much appreciated.
