Three questions about output results from EnergyPlus:
1) How can I set to especific Summary Report EnergyPlus in OpenStudio? Example: I want the "SummaryReport: ZoneCoolingSummaryMonthly". Is it possible to activate this directly from OpenStudio? Some measure for this?
2) Is there some way to output a graphic result from the Thermal Load HVAC? I saw this graphic in a paper from NREL. How to obtain this? Some measure?
[IMG]http://i57.tinypic.com/2drfl9x.jpg[/IMG]
3) When I use the Ideal Air Loads, I want to know the simultaneous thermal load of a group of Thermal Zones to choose the capacity of my system. Is there some field in EnergyPlus to report this? Or the only way to do this is creating a system with the thermal zones and set autocalculate?
