Is there a way to find if the economizer is active during the hour in the hourly report. The output variable "Air System Outdoor Air Economizer Status" only indicated if there is a potential for economizer usage, not necessarily if it is active. Not sure if checking the outdoor air ratio is good idea esp for a VAV system as the economizer could operate part hours too.
