Hi,
In a project, a thermal zone with a doa and a default water to air heat pump, cooling thermostat 22°C, the maximum outdoor temp is 21°C, and density correction fctor is 0.731, the resultant are:
Design Size Rated Total Cooling Capacity 53964 W
(the first)
CALCULATED DESIGN LOAD 18,117 W
If the there is no heat gain from DOA, why is the difference between results?
There is no safety factor in the project.
How can i attach a project?
