Hello,
I'm searching a way to maintain the solar radiation (direct and diffuse) constant over more than a day. I'm opening again a discussion that exist already (Maintain the daylight more than 24h?).
- To maintain the intensity, it only needs to manipulate the weather data. But there are troubles with the daylight. When the night comes, all the radiations are forced to be at zero.
- To maintain the duration, as it can be seen in the previous discussion, the building can be located in the North Pole. It works to maintain the sun in daylight constant but no the direct. Indeed, the Direct Radiation depend on the cardinal direction and so the sun is turning around the building. As the building is not circular (but rectangular), the amount of radiation receives in the building is not constant.
I'm wondering if someone know a solution to implement this kind of experiment.
Thanks a lot
