Hi! I modeled my building with OpenStudio. I'm doing simulations with jeplus using the in.idf("1-ModelToIdf-0" folder) created by OpenStudio. Reading this question I started to question what is the diference between the in.idf and the out.idf because when I use the in.idf in jeplus I donĀ“t observe any strange results. Can you tell me what is the correct *.idf file to use to run simulations in jeplus? Thank you
