Calculating total annual schedule hours using OpenStudio measure
I'm trying to figure out how to calculate total annual schedule hours for a ScheduleRuleset using an OS measure. Consider the following application. Given a total annual hot water consumption value (gal/year), and a proposed fractional schedule for usage (with any number of Rules to specify different schedules for weekdays, weekends, seasonal closure periods, etc.), calculate the peak flow rate input you should specify for the WaterUseEquipment object.
