What is the best way to model Service Hot Water for a MidriseApartment in OpenStudio? Assuming each apartment unit has its own water heater, is it more appropriate to select separate water use connections and water use equipments for each of the apartment units, which is very time consuming, or is it okay to select a water use connection for a group of the apartment units located in each floor or in the whole building?
