Hi everyone I'm trying to model an existing building in eQuest 3.65.
The building has a chilled water loop and a hot water loop (the same pumps changeover to pump HW in winter and CHW in summer).
All apartments have a non-ducted 2-pipe Fan Coil Unit. Nothing controls the coil (there's no 2-way valve), there's just a fan selector (LOW-SPEED/HI-SPEED/OFF), and there is no outside air being supplied to the apartments.
I'm struggling to understand how to properly model this in eQuest:
Should I create one HVAC SYSTEM (type FCU) per zone? Or one FCU system serving all of my zones? (Both seem to work, but I'm guessing there could be a drawback to using one versus the other)
What is the easiest way to ensure the outside air is zero?
How should I configure the FCU to mimic as closely as possible the (lack of) controls I have?
Thanks for any insight you can provide!
