Hi all,
I wanted to know if I can use the IDF file in OpenStudio output folders to edit some simulation parameters in energyplus; and will the changes in IDF file affect the OpenStudio model as well? If so, could you please let me know which of the IDF files is the right one to use? Because After running simulation in OpentStudio, I have two output folders which have the IDF files. One is under 3-Userscript-0 and the other is under 4-EnergyPlusPreProcess-0.
Thanks, Maryam
