I've been reading about this subject and I know I can do it with a measure. But in which part I will put the opening area?? And another question.. if I put a high flow rate in the Operable windows, this will seems like natural ventilation?
| 1 | initial version |
| 2 | retagged |
| 3 | No.3 Revision |
area?? Because I want OpenStudio finds the flow rate of a window due to natural ventilation.
| 4 | No.4 Revision |
I've been reading about this subject and I know I can do it with a measure. But in which part I will put the opening area?? Because I want OpenStudio finds the flow rate of a window due to natural ventilation.
And another question.. if I put a high flow rate in the Operable windows, this will seems like natural ventilation?ventilation.
| 5 | No.5 Revision |
I've been reading about this subject and I know I can do it with a measure. But in which part I will put the opening area?? Because I want OpenStudio finds the flow rate of a window due to natural ventilation.ventilation. And other thing, not all the windows I have in a zone are operables, there is a problem with that??
| 6 | No.6 Revision |
I've been reading about this subject and I know I can do it with a measure. But in which part I will put the opening area?? Because I want OpenStudio finds the flow rate of a window due to natural ventilation. And other thing, not all the windows I have in a zone are operables, there is a problem with that??that??.
