Hello, I'm modeling a plant in which a constant-speed circulation pump in the condenser loop must be on/off according to the zone air source heat pump on/off profile. Is there any set point-manager which is appropriate for that? Thank you so much.
| 1 | initial version |
| 2 | retagged |
