Hi,
I need to know if I have to put in my zones Space Infiltration Design flow rates and Space infiltration Effective Leakage or I can use one of them?? Im having trouble to run my model and I don´t know if that is the cause.
| 1 | initial version |
Hi,
| 2 | Suggested edit |
Hi,
Here is the error im seeing:
Program Version,EnergyPlus, Version 8.5.0-c87e61b44b, YMD=2016.05.27 13:38,IDD_Version 8.5.0 *** IDF Context for following error/warning message: *** Note -- lines truncated at 300 characters, if necessary... *** 10589 ZoneInfiltration:DesignFlowRate, *** indicated Name=189.1-2009 - Office - OpenOffice - CZ4-8 Infiltration *** Only last 2 lines before error line shown..... *** 10590 189.1-2009 - Office - OpenOffice - CZ4-8 Infiltration, !- Name *** 10591 , !- Zone or ZoneList Name * Severe * IP: IDF line~10591 Error detected in Object=ZONEINFILTRATION:DESIGNFLOWRATE, name=189.1-2009 - OFFICE - OPENOFFICE - CZ4-8 INFILTRATION * ~~~ * Field [Zone or ZoneList Name] is required but was blank * Warning * IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details. * Severe * IP: Blank "required" fields found in input * Severe * IP: Out of "range" values and/or blank required fields found in input * Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=3 ..... Last severe error=IP: Out of "range" values and/or blank required fields found in input *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 1 Warning; 3 Severe Errors; Elapsed Time=00hr 00min 1.32sec
| 3 | retagged |
Hi,
