Hi,
The model running period is set to start from Jan 1 till Dec 31, but the generated spreadsheet only gives this: simdays=1 simdays=1 simdays=1 simdays=1 simdays=1 simdays=1 simdays=1 simdays=365 as the results when the 'running period' is selected under reporting frequency under output:variable.
When the 'montly' is selected it starts with July 21 and Jan 21 before getting to normal. Also The Energy+ is generating other outputs that I am not selected.
I have checked everything, but can't find any problem.
As I can't upload the file... Any suggestion would be appreciated. such as what should I check.
How to get the points to upload the idf.file?
Appreciated for the help!
Leshi
