Hi! I'm using OpenStudio to model a supermarket. As I'm trying to study the HVAC consumptions the several freezers(and also other electric equipment) that the supermarket has will influence the HVAC consumptions. In my model "Loads" tab I have 3 fields to fill: Fraction Latent, Fraction Radiant and Fraction Lost. I don't know, for each equipment that a supermarket has, what values should I introduce in this fields. Is there any informations/tables where we can obtain this values for each different equipment? Thank you
