I have a working energyplus .idf. When I try to import it into OpenStudio I get this error (in a tiny window):
The collection is INVALID at strictness level 'Draft', because of the errors:
Field level data error of type DataType .
Error is in an object of type 'Schedule:Week:Compact', named 'DHWDistWk1', in field 1.
Additional information about the error type: field-level data is of an incorrect type.
I found this, https://unmethours.com/question/1289/scheduleweekcompact-error-when-importing-idf-into-openstudio/
Is schedule:week:compact the only schedule format that doesn't work? Are there other known issues with idf import documented somewhere?
