Hi every one I'm trying to optimizing a building design, by coupling ENErgyplus and an optimisation tools GENOPT . for that , i'm using a Hybrid Generalized Pattern Search Algorithm with Particle Swarm Optimization Algorithm (GPSPSOCCHJ) for discrete and continous variable. but i can't understand how to determine the number of particle for this optimisation .
Please , give an idea about the mean of this parametr(NumberOfParticle ).
Thanks
++the command file is : * GenOpt example command file MWetter@lbl.gov, 06/18/2003 */ Vary{ Parameter{ // azimuthangle
Name = x1;
Min = -180.0;
Ini = 0.0;
Max = 180.0;
Step = 90.0;
} Parameter{ // high windows size
Name = x2;
Min = 0.8;
Ini = 1.6;
Max = 1.6;
Step = 0.4;
Parameter{ //infiltrationrate Name = x4; Min = 0.5; Ini = 0.5; Max = 2.0; Step = 0.5;
Parameter{ //ventilationrate Name = x5; Min = 0.0; Ini = 0.0; Max = 2.0; Step = 0.5; } Parameter{ // windowstype Name = x6; Ini = 1; Values = "100, 101" ; Type = SET; } Parameter{ // wall-exterior-type Name = x8; Ini = 1; Values = "EWQ23M91,EWQ23M51,EWQ21M51,EWQ21M91,EWQ25M51,EWQ25M91,EWQ27M51,EWQ27M91,EWQ29M51,EWQ29M91" ; Type = SET; }
Parameter{ // roof-exterior-type Name = x10; Ini = 1; Values = "ERQ23M91,ERQ23M51,ERQ21M51,ERQ21M91,ERQ25M51,ERQ25M91,ERQ27M51,ERQ27M91,ERQ29M51,ERQ29M91" ; Type = SET; } } OptimizationSettings{ MaxIte = 10000; MaxEqualResults = 200; WriteStepNumber = false; UnitsOfExecution = 4; } Algorithm{ Main = GPSPSOCCHJ; NeighborhoodTopology = vonNeumann; NeighborhoodSize = 5; NumberOfParticle = ; NumberOfGeneration = 50; Seed = 1; CognitiveAcceleration = 2.05; SocialAcceleration = 2.05; MaxVelocityGainContinuous = 0.2; MaxVelocityDiscrete = 4; ConstrictionGain = 1; MeshSizeDivider = 2; InitialMeshSizeExponent = 0; MeshSizeExponentIncrement = 1; NumberOfStepReduction = 4; }
