New OS user. I have run basic simulations on this model previously with success. Today I exported an .IDF for EnergyPlus, which has caused failures on all of my simulations since that .IDF export. Any help will be appreciated. Below is the output text.
Missing Energy+.ini
EnergyPlus Starting
EnergyPlus-Windows-64 8.1.0.009, YMD=2014.12.04 15:02
Processing Data Dictionary
Processing Input File
Initializing Response Factors
Calculating CTFs for "ASHRAE 189.1-2009 EXTROOF EPDM CLIMATEZONE 6", Construction #1
Calculating CTFs for "ASHRAE 189.1-2009 EXTWALL MASS 5 LAM CLT CLIMATEZONE 6", Construction #2
Calculating CTFs for "ASHRAE 189.1-2009 EXTWALL MASS 8IN PC CLIMATEZONE 6", Construction #3
Calculating CTFs for "ASHRAE 189.1-2009 EXTWALL MASS CLIMATEZONE 6", Construction #4
Calculating CTFs for "EXTERIOR DOOR", Construction #6
Calculating CTFs for "EXTSLAB 4IN CLIMATEZONE 1-8", Construction #7
Calculating CTFs for "INTERIOR CEILING", Construction #8
Calculating CTFs for "INTERIOR DOOR", Construction #9
Calculating CTFs for "INTERIOR WALL", Construction #12
Initializing Window Optical Properties
Initializing Solar Calculations
Allocate Solar Module Arrays
Initializing Zone Report Variables
Initializing Surface (Shading) Report Variables
Computing Interior Solar Absorption Factors
Determining Shadowing Combinations
Computing Window Shade Absorption Factors
Proceeding with Initializing Solar Calculations
Initializing Surfaces
Initializing Outdoor environment for Surfaces
Setting up Surface Reporting Variables
Initializing Temperature and Flux Histories
Initializing Window Shading
Computing Interior Absorption Factors
Computing Interior Diffuse Solar Absorption Factors
Computing Interior Diffuse Solar Exchange through Interzone Windows
Initializing Solar Heat Gains
Initializing Internal Heat Gains
Initializing Interior Solar Distribution
Initializing Interior Convection Coefficients
Gathering Information for Predefined Reporting
Completed Initializing Surface Heat Balance
Calculate Outside Surface Heat Balance
Calculate Inside Surface Heat Balance
Calculate Air Heat Balance
Initializing HVAC
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Performing Zone Sizing Simulation
...for Sizing Period: #1 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS DB=>MWB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
...for Sizing Period: #2 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS DP=>MDB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
...for Sizing Period: #3 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS ENTH=>MDB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
...for Sizing Period: #4 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS WB=>MDB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
...for Sizing Period: #5 MILWAUKEE MITCHELL INTL AP ANN HTG 99.6% CONDNS DB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
...for Sizing Period: #6 MILWAUKEE MITCHELL INTL AP ANN HTG WIND 99.6% CONDNS WS=>MCDB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
...for Sizing Period: #7 MILWAUKEE MITCHELL INTL AP ANN HUM_N 99.6% CONDNS DP=>MCDB
Calculating System sizing
Initializing Simulation
Reporting Surfaces
Initializing New Environment Parameters
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Starting Simulation at 07/21 for MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS DB=>MWB
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Starting Simulation at 07/21 for MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS DP=>MDB
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Starting Simulation at 07/21 for MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS ENTH=>MDB
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Starting Simulation at 07/21 for MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS WB=>MDB
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Starting Simulation at 01/21 for MILWAUKEE MITCHELL INTL AP ANN HTG 99.6% CONDNS DB
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Starting Simulation at 01/21 for MILWAUKEE MITCHELL INTL AP ANN HTG WIND 99.6% CONDNS WS=>MCDB
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Starting Simulation at 01/21 for MILWAUKEE MITCHELL INTL AP ANN HUM_N 99.6% CONDNS DP=>MCDB
Writing tabular output file results using HTML format.
Computing Life Cycle Costs and Reporting
Writing final SQL reports
**FATAL:Error condition occurred. Previous Severe Errors cause termination.
EnergyPlus Run Time=00hr 00min 22.04sec
click to hide/show revision 2
retagged
Missing Energy+.ini
EnergyPlus Starting
Initializing HVAC
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Reporting Surfaces
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Trouble-shooting IDF Errors
 Missing Energy+.ini
Energy+.ini EnergyPlus Starting
Starting EnergyPlus-Windows-64 8.1.0.009, YMD=2014.12.04 15:02
15:02 Processing Data Dictionary
Dictionary Processing Input File
File Initializing Response Factors
Factors Calculating CTFs for "ASHRAE 189.1-2009 EXTROOF EPDM CLIMATEZONE 6", Construction #1
#1 Calculating CTFs for "ASHRAE 189.1-2009 EXTWALL MASS 5 LAM CLT CLIMATEZONE 6", Construction #2
#2 Calculating CTFs for "ASHRAE 189.1-2009 EXTWALL MASS 8IN PC CLIMATEZONE 6", Construction #3
#3 Calculating CTFs for "ASHRAE 189.1-2009 EXTWALL MASS CLIMATEZONE 6", Construction #4
#4 Calculating CTFs for "EXTERIOR DOOR", Construction #6
#6 Calculating CTFs for "EXTSLAB 4IN CLIMATEZONE 1-8", Construction #7
#7 Calculating CTFs for "INTERIOR CEILING", Construction #8
#8 Calculating CTFs for "INTERIOR DOOR", Construction #9
#9 Calculating CTFs for "INTERIOR WALL", Construction #12
#12 Initializing Window Optical Properties
Properties Initializing Solar Calculations
Calculations Allocate Solar Module Arrays
Arrays Initializing Zone Report Variables
Variables Initializing Surface (Shading) Report Variables
Variables Computing Interior Solar Absorption Factors
Factors Determining Shadowing Combinations
Combinations Computing Window Shade Absorption Factors
Factors Proceeding with Initializing Solar Calculations
Calculations Initializing Surfaces Initializing Outdoor environment for Surfaces
Surfaces Setting up Surface Reporting Variables
Variables Initializing Temperature and Flux Histories
Histories Initializing Window Shading
Shading Computing Interior Absorption Factors
Factors Computing Interior Diffuse Solar Absorption Factors
Factors Computing Interior Diffuse Solar Exchange through Interzone Windows
Windows Initializing Solar Heat Gains
Gains Initializing Internal Heat Gains
Gains Initializing Interior Solar Distribution
Distribution Initializing Interior Convection Coefficients
Coefficients Gathering Information for Predefined Reporting
Reporting Completed Initializing Surface Heat Balance
Balance Calculate Outside Surface Heat Balance
Balance Calculate Inside Surface Heat Balance
Balance Calculate Air Heat Balance
Initializing HVAC
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Balance Initializing HVAC Warming up Warming up Warming up Warming up Warming up Warming up Performing Zone Sizing Simulation
Simulation ...for Sizing Period: #1 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS DB=>MWB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
DB=>MWB Warming up Warming up Warming up Warming up Warming up Warming up Performing Zone Sizing Simulation
Simulation ...for Sizing Period: #2 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS DP=>MDB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
DP=>MDB Warming up Warming up Warming up Warming up Warming up Warming up Performing Zone Sizing Simulation
Simulation ...for Sizing Period: #3 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS ENTH=>MDB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
ENTH=>MDB Warming up Warming up Warming up Warming up Warming up Warming up Performing Zone Sizing Simulation
Simulation ...for Sizing Period: #4 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS WB=>MDB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
WB=>MDB Warming up Warming up Warming up Warming up Warming up Warming up Performing Zone Sizing Simulation
Simulation ...for Sizing Period: #5 MILWAUKEE MITCHELL INTL AP ANN HTG 99.6% CONDNS DB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
Simulation ...for Sizing Period: #6 MILWAUKEE MITCHELL INTL AP ANN HTG WIND 99.6% CONDNS WS=>MCDB
Warming up
Warming up
Warming up
Warming up
Warming up
Warming up
WS=>MCDB Warming up Warming up Warming up Warming up Warming up Warming up Performing Zone Sizing Simulation
Simulation ...for Sizing Period: #7 MILWAUKEE MITCHELL INTL AP ANN HUM_N 99.6% CONDNS DP=>MCDB
DP=>MCDB Calculating System sizing
sizing ...for Sizing Period: #1 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS DB=>MWB
DB=>MWB Calculating System sizing
sizing ...for Sizing Period: #2 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS DP=>MDB
DP=>MDB Calculating System sizing
sizing ...for Sizing Period: #3 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS ENTH=>MDB
ENTH=>MDB Calculating System sizing
sizing ...for Sizing Period: #4 MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS WB=>MDB
WB=>MDB Calculating System sizing
sizing ...for Sizing Period: #5 MILWAUKEE MITCHELL INTL AP ANN HTG 99.6% CONDNS DB
sizing ...for Sizing Period: #6 MILWAUKEE MITCHELL INTL AP ANN HTG WIND 99.6% CONDNS WS=>MCDB
WS=>MCDB Calculating System sizing
sizing ...for Sizing Period: #7 MILWAUKEE MITCHELL INTL AP ANN HUM_N 99.6% CONDNS DP=>MCDB
DP=>MCDB Initializing Simulation Reporting Surfaces
Surfaces Initializing New Environment Parameters
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Parameters Warming up {1} Warming up {2} Warming up {3} Warming up {4} Warming up {5} Warming up {6} Starting Simulation at 07/21 for MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS DB=>MWB
DB=>MWB Initializing New Environment Parameters
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Parameters Warming up {1} Warming up {2} Warming up {3} Warming up {4} Warming up {5} Warming up {6} Starting Simulation at 07/21 for MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS DP=>MDB
DP=>MDB Initializing New Environment Parameters
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Parameters Warming up {1} Warming up {2} Warming up {3} Warming up {4} Warming up {5} Warming up {6} Starting Simulation at 07/21 for MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS ENTH=>MDB
ENTH=>MDB Initializing New Environment Parameters
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Parameters Warming up {1} Warming up {2} Warming up {3} Warming up {4} Warming up {5} Warming up {6} Starting Simulation at 07/21 for MILWAUKEE MITCHELL INTL AP ANN CLG .4% CONDNS WB=>MDB
WB=>MDB Initializing New Environment Parameters
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Parameters Warming up {1} Warming up {2} Warming up {3} Warming up {4} Warming up {5} Warming up {6} Starting Simulation at 01/21 for MILWAUKEE MITCHELL INTL AP ANN HTG 99.6% CONDNS DB
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Parameters Warming up {1} Warming up {2} Warming up {3} Warming up {4} Warming up {5} Warming up {6} Starting Simulation at 01/21 for MILWAUKEE MITCHELL INTL AP ANN HTG WIND 99.6% CONDNS WS=>MCDB
WS=>MCDB Initializing New Environment Parameters
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Parameters Warming up {1} Warming up {2} Warming up {3} Warming up {4} Warming up {5} Warming up {6} Starting Simulation at 01/21 for MILWAUKEE MITCHELL INTL AP ANN HUM_N 99.6% CONDNS DP=>MCDB
DP=>MCDB Writing tabular output file results using HTML format.
format. Computing Life Cycle Costs and Reporting
Reporting Writing final SQL reports
reports **FATAL:Error condition occurred. Previous Severe Errors cause termination.
termination. EnergyPlus Run Time=00hr 00min 22.04sec
22.04sec
