Hi, How to customize lighting power density or watts at zone level in OS ? I found when a space is assigned to a space type, at Space-> Loads tab, the lighting definition is grey out and can't customize lighting power from space to space. It only can be changed from space type template.
Is there a way to define individual space lighting power for different spaces in OS ?
Thank you very much in advance.!
