Is there a software other than openstudio plugin to edit HVAC in ASHRAE 90.1 prototype models? https://www.energycodes.gov/development/commercial/90.1_models
What I'm told is that openstudio doesn't import HVAC and that i need the legacy openstudio plugin to be able to view HVAC, IDF editor is needed if I want to edit HVAC parameters. Isn't there a user interface software like designbuilder that helps work with models and make some changes through a user interface that is simple to use.
thanks,
