I want your help about warnings and how they can be eliminated (Although I understand, they are not all of them critical).
Here 's my model: https://we.tl/5Cmmzhz0UY
ModelToIdf Warnings:
Warning: Both surfaces 'Surface 40', and 'Surface 27 reference the same construction 'Interior Wall' but it is not symmetric, creating a reversed copy.
EnergyPlus Warnings:
Warning : IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details.
In the out.audit file I see this Warning IP: IDF line~1976 Object=LIGHTS, name=189.1-2009 - OFFICE - CORRIDOR - CZ4-8 LIGHTS 1, entered with less than minimum number of fields. * ~~~ * *Attempting fill to minimum. * Add * 1.00000000000000 ! field=>Fraction Replaceable
Warning: ProcessSchedulelnput: ScheduleTypeLimits='CONTROLMODE', Unit Type='CONTROLMODE' is invalid.
Warning: ProcessSchedulelnput: ScheduleTypeLimits=ΊΙΝΕARPOWERDENSITY", Unit Type="LINEARPOWERDENSITY" is invalid.
Warning: ProcessSchedulelnput: ScheduleTypeLimits='VOLUMETRICFLOWRATE", Unit Type=’VOLUMETRICFLOWRATE’ is invalid. Warning: GetHTSurfaceData: Surfaces with interface to Ground found but no 'Ground Temperatures' were input. Found first in surface =SURFACE 1 Defaults, constant throughout the year of (18.0) will be used.
Warning: CheckUsedConstructions: There are 4 nominally unused constructions in input. For explicit details on each unused construction, use Output:Diagnostics,DisplayExtraWarnings;
Warning: Output:Meter: invalid Name='GAS:FACILITY' - not found.
Warning: Output:Meter: invalid Name='DISTRICTCOOLING:FACILITY' - not found.
Warning: Output:Meter: invalid Name='DISTRICTHEATING:FACILITY' - not found.
