I am getting the following warnings, and I wanted to know the significance of these. I picked Cooling coil water nad Chiller:Electric: EIR based on an example idf file. Error files include:-
* Warning * In calculating the design coil UA for Coil:Cooling:Water COIL COOLING WATER 1 * ~~~ * no apparatus dew-point can be found for the initial entering and leaving conditions; * ~~~ * the coil outlet design conditions will be changed to correct the problem. * ~~~ * The initial design conditions are: Tair,in = 25.9241 * ~~~ * Wair,in = 1.816273E-002 * ~~~ * Twater,in = 7.5000 * ~~~ * Tair,out = 12.8000 * ~~~ * Wair,out = 8.281818E-003 * ~~~ * The revised design conditions are: Tair,out = 12.7997 * ~~~ * Wair,out = 8.281922E-003 * Warning * Chiller:Electric:EIR = CHILLER ELECTRIC EIR 1: Integrated Part Load Value (IPLV) calculated is not at the AHRI test condition. * ~~~ * Check limits in Cooling Capacity Function of Temperature Curve, Curve Type = BIQUADRATIC, Curve Name = CURVE BIQUADRATIC 1 * ~~~ * Check limits in EIR Function of Temperature Curve, Curve Type = BIQUADRATIC, Curve Name = CURVE BIQUADRATIC 2 * Warning * SetpointManager:Scheduled="SETPOINT MANAGER SCHEDULED 1" * ~~~ * ...setpoint node conflicts with another setpoint manager. * ~~~ * ...conflicting setpoint manager = SetpointManager:OutdoorAirReset:"AHU1 OUTLET SETPOINT" * ~~~ * ...conflicting node name = AIR OUTLET NODE1 * ~~~ * ...control type variable = Temperature
